Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1972 Perguntas Visualizar todos
Battery turn off at 30 % charge
Hello,
I just bought a Iphone 3gs and my Problem is that if the battery reaches a level around 30% , the phone just turns off . The only way to get it back running is to charge it up , so that is has more then 30%. Can you tell me how to fix the problem please ?? fyi i dont have the phone jailbreaked or anything , i just bought it on ebay und received it reseted without any programs on it.
yours sincerly
Esta pergunta é pertinente?
Pontuação 0
Comentários:
done ;) thanks again !
por
Adicionar um comentário
1 Resposta
Solução escolhida
Try replacing the battery and if that doesn't work replace the logic board.
Imagem de iPhone 3GS Battery
Produto
iPhone 3GS Battery
$14.99
Esta resposta foi útil?
Pontuação 1
Comentários:
+...I would definitely start with the battery. After that there are a few more things you can try before you start replacing a logic board....
por
ok thanks but why do you think its the logic board ?? the phone just runs fine and its far too expensive to exchange a logic board on a 3gs i just paid 214 euro for mine
por
Try replacing the battery first and that will probably fix it.
por
ok i just bought this one :
http://www.ebay.de/itm/120818059443?ssPa...
hope it will work
por
It should work.
por
Mostrar mais 4 comentários
Adicionar a sua resposta
Dominic será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,091
