Ir para o conteúdo principal
Repair guides and support for top and front loading Whirlpool brand washers.
420 Perguntas Visualizar todos
Whirlpool wtw4855hw3 is blinking repetitively in sensing fill
Hi everyone, I went to run a small load of laundry in the washer and when I go to start the load it just constantly blinks sensing fill. It goes to act like it starts and then the lid locked starts to blink along with the sensing fill. Any idea what it could be? It’s a whirlpool and here is the model number: wtw4855hw3
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @karenmurzynsky
Here's the tech sheet for the washer that may help.
Run the washer in the service diagnostic mode as described by the tech sheet (bottom left of 1st page), and check what error codes are being displayed.
The fault/error code display method table (bottom middle of 1st page) shows how to interpret the status LEDs on the washer to know what the error code is.
Once you know what the error code (if any) is, look up the error code list (top right of 1st page) to find out what the error code means.
Hopefully a start to finding out what's happening.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Karen Murzynsky será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 85
