Ir para o conteúdo principal
Repair guides and support for top and front loading Whirlpool brand washers.
421 Perguntas Visualizar todos
Need to bypass lid lock Whirlpool cabrio WTW8040DW4
Need to bypass lid lock, looks like pins 1,4,5, and7 should all connect am I correct?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I'd like to add this to to holmy previous answere, I had to hold the blue wire , pin 4, to pins 1,5, and 7 for 30 seconds to make the machine think it was unlocked, and then remove it to make the machine think it was locked. I'm not completely sure if that as actually necessary or not.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
The lid lock assembly part number is W10810403 and the lid lock pins are 1, 4, 5, and 7.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I tied 1,4,5,7 together and it worked, but only once, looks like I need to check the connects on the main controller board, j-6, and try again, I'll get back with you thanks, Greg Winchester
por
Adicionar a sua resposta
Gregory Winchester será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 154
