Ir para o conteúdo principal
Released in May 2020, the 13" MacBook Pro features quad-core Intel 10th generation Core i5 and i7 processors, and Intel Iris Plus integrated graphics. (Model A2251/EMC3348 with four Thunderbolt 3 ports)
MacBook won't stay in dfu mode long enough to restore?
I wanted to do DFU mode which is restoring the Macbook but in the last step is jumps out and goes to locked photo!! I can't install from the internet recovery like 2014 model nither from USB bootable!
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Do you get any errors in Configurator?
por
Adicionar um comentário
1 resposta
What is preventing the OS reinstall from Recovery Mode? The model you have should support it. Does it give you an error when you try to reinstall from Recovery Mode? If so, what is the error? Do you know if the device is Activation Locked to an Apple ID?
Esta resposta foi útil?
Pontuação 0
6 comentários:
Before this I went to Recovery mode which is Comand+R but I did a mistake and I formatted SSD then never boot to recovery mode or passed the Apple logo.
por
Macbook is not passing apple logo, stuck on apple logo
por
Maybe you can try holding Command+Option+Shift+R on startup. That should hopefully open a version of Internet Recovery Mode that will allow you to reinstall the OS that shipped with the computer. You could also try Command+Option+R. Good luck!
por
I did this as well. But it goes to black screen never apple logo with progress bar are showing up
por
Interesting! It sounds like it may have an issue with the firmware—I'm not sure how to resolve that if DFU mode isn't working for you. It might require contacting Apple and sending it into them to resolve, or maybe a local repair shop would be able to help you out? Good luck!
por
Exibir mais 1 comentário
Adicionar a sua resposta
Armin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 711
