Is replacement battery for the se first generation &
is the replacement battery for the se first generation the same as the one for the apple watch series 1
Esta é uma boa pergunta?
Greetings,
No, according to Apple Website the original Apple watch SE the model you have is either a 2351 40mm or the 2352 44mm.
That being the case the battery I found on Ifixit that matches those model numbers is located here.
Apple Watch (40 mm SE and Series 5) Battery
Please verify for yourself that the model numbers I have found from apple are correct and visit the link above to purchase if everything lines up.
From Apples Website It also shows you in the watch application on your phone the exact model number.
Hope this helps, Monte
To learn which Apple Watch you have, use its model number:
In Japan, if you have an Apple Watch Series 2 and the part number ends with "J/A," you can use Apple Pay on your device to ride transit and make purchases in stores.
To find your case size and more information, check the engraving on the back of your Apple Watch.
40mm case (Model: A2351)
44mm case (Model: A2352)
Space gray, gold, or silver aluminum
Ion-X glass, Retina display, and ceramic back
Space gray or silver aluminum
Ion-X glass, sapphire crystal, Retina display, and ceramic back with Nike logo
40mm case (Model: A2353 North America; A2355 Europe, Asia Pacific, and China mainland)
44mm case (Model: A2354 North America; A2356 Europe, Asia Pacific, and China mainland)
Space gray, gold, or silver aluminum with a red ring on the Digital Crown
Space gray or silver aluminum with a red ring on the Digital Crown
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 62
