Ir para o conteúdo principal
Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
103 Perguntas Visualizar todos
Having problems trying to rebuild my OS
build  Bridge OS 7.5 (20P5058),
@danj I’m having an issue with a 2020 MacBook Air
Its flashing the folder logo, internet recovery through WiFI gives error 2003f.
Trying to install the OS via USB it goes into the system and asks what I want to boot from but when I select the USB file it says security won’t let me boot from USB, change security by pressing command-r, when I do that it takes me to internet recovery again with no security option and the fan is running full speed when trying internet recovery.
Any ideas ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
The drive is encrypted so it won’t let you access it. You’ll need to visit an Apple Store for help.
Esta resposta foi útil?
Pontuação 0
16 comentários:
@danj i managed to get the os loaded via ethernet but now i sometimes get random restarts. there is a panic log but i cant make heads or tails of it
por
@tech_ni - can you export it into a PDF and post it here so we can see it.
por
@danj
panic(cpu 1 caller 0xfffffff020774a68): x86 CPU CATERR detected
Debugger message: panic
Memory ID: 0x6
OS release type: User
OS version: 20P5058
macOS version: 19H2
Kernel version: Darwin Kernel Version 22.5.0: Mon Apr 24 20:06:41 PDT 2023; root:xnu-8796.121.2~1/RELEASE_ARM64_T8010
KernelCache UUID: 898E82ABB7B6D9C47BA18414767F7655
Kernel UUID: A04DA547-BD69-39FF-A0E2-D59ED179A076
Boot session UUID: 75527CA8-CD8C-477F-BEAB-E36ED4BC714A
iBoot version: iBoot-8422.121.2
secure boot?: YES
roots installed: 0
x86 EFI Boot State: 0xd
x86 System State: 0x0
x86 Power State: 0x0
x86 Shutdown Cause: 0x3
x86 Previous Power Transitions: 0x70707060400
PCIeUp link state: 0x1614
macOS kernel slide: not available
Paniclog version: 14
por
@tech_ni - Is that it?? This is way too small. The panic call memory state should follow this. I haven’t looked at Big Sur and newer back traces so things might have changed, besides this looks like this is a M series system not Intel is this the Late 2020 system by chance?
por
@danj there is more to it but i cant add it, intel i3
por
Exibir mais 11 comentários
Adicionar a sua resposta
daniel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 91
