Ir para o conteúdo principal
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
159 Perguntas Visualizar todos
My right joystick wont read horizontal inputs.
The right analog stick on my Xbox controller will not read horizontal inputs but at the same time, when I go into the controller settings and enter the button testing it reads as if the right stick is at full lock to the left. What is causing this and is there any way to fix it without the access to basic tools, like screwdrivers
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There are a number of things that could be the culprit, but you can't even assess the situation without opening the controller.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Michael Wilson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 30
