Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
OWC Aura Pro X2 SSD won't fit
Trying to replace the SSD with the Aura iFixit recommends but it doesn't go down far enough to replace the screw.
Update (05/11/23)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Can you post some pics so we can see things. Show us the screw location with the drive in place. A second looking down into the socket.
Esta resposta foi útil?
Pontuação 0
2 comentários:
updated with photos
por
@lumivuohi - I can’t tell for sure as I can’t see deeply enough T into the slot to see if you have a bent pin blocking things.
Assuming it’s not then you need to apply a tad more pressure sliding the SSD into the slot. Make sure you don’t lift it up as that could damage things.
Hint! There is a key way in the connector the gap you see now needs to almost be gone when fully inserted.
por
Adicionar a sua resposta
Lumivuohi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 90
