Washer stops before the drain cycle
Whenever you put the washer on a regular or heavy wash cycle, it will pause it stays green, but does not drain or spin but if I move the dial to drain and spin, then it will drain in spin
Esta é uma boa pergunta?
Pontuação
Just to make sure that I'm understanding the issue correctly, the washer will fill, but won't start the spin cycle once it has finished filling, and will not drain?
por Jacob Mehnert
yes but if i put it on drain and spin it works fine
por timmason911
@x0pkiw9jorsolmn
What is the model number of the washer?
por jayeff
