How cold is too cold?
So I live in alaska and I accedentally left my Mac in my car in the winter (-10 degrees). :/ I know its not good for it, but im wondering how cold is too cold?
Esta é uma boa pergunta?
Some of the capacitors and the LCD have liquids in them that can freeze at very low temps.
The real issue is trying to use your system at such temps. The hard disk platters shrink when they are chilled (Aluminum) so tracking, data reads & writes can encounter problems. If you do write any data on the disks you could encounter a non-readable disk when you try accessing it after it has warmed.
Lastly, if you don't let the system warm up carefully in a warm building condensation can build up inside.
Best to allow your system a good three-four hours or more to warm up sealed in a plastic bag before entering inside.
Esta resposta foi útil?
Thanks Dan that makes sense, I will try not to leave it in the cold.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 4,997
