Ir para o conteúdo principal
The Wacom Intuos Pro is a graphic design tablet designed by Wacom. The device comes with, a type-C charger, the Pro pen 2, and the Pen holder.
7 Perguntas Visualizar todos
Removing battery for USB only usage?
Is possible to simply remove the battery inside PTH-660? In a studio setup, it is not really needed. USB is better!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
You can remove the battery but you'll need a soldering iron. You can follow this ifixit guide here.
Esta resposta foi útil?
Pontuação 0
OK, thanks, but removing the battery puts the tablet in "USB Only" mode?
Nevermind the question.
I removed the battery and I can confirm: the tablet Works Without the battery. Just a brief message that the battery il low, but after that IT WORKS
Pontuação 0
Adicionar a sua resposta
Luca Di Meo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 202
