Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1198 Perguntas Visualizar todos
When iPhone X is plugged in, it’s stuck on apple logo, how do I fix?
Hello, my iPhone X doesn’t not turn on until I plug in the charger, even then it is stuck on the apple logo. It just blinks on and off. Does anyone know what could be causing this ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Liz,
Given that the iPhone X is now six years old, it's not surprising to have things wear out. Of course, since virtually the entire phone is made up of solid state electronics that really don't "wear out", the battery is really the only part that dies from repeated use. Well, there is the charging port, but that's a slightly different situation.
Anyway, while it's really hard to tell for sure, it's quite possible your battery has given up the ghost and doesn't have enough power to run the phone, or even let it boot. I'd suggest trying a different charger and a different charging cable. If that's not possible, try using them with a different phone and see if they work on another device.
If you've verified the charger and the cord are good, check the charging port itself. Shine a bright light inside and check for dirt, dust, pocket lint or any other kind of debris that might have found its way inside. Clean it out with some 90% or higher isopropyl alcohol, a toothpick, and a piece of eyeglass cleaning cloth.
If you still have no joy from the phone, the next thing to do is probably replace the battery. If it won't take a charge then the phone can't power up, so having checked the charger, cord and port, the battery is the next most likely suspect. Fortunately the iPhone X is getting older so the parts are getting cheaper, so it won't break the bank to put a new battery in. Here's the guide to show you step by step how to do it yourself.
iPhone X Battery Replacement - iFixit Repair Guide
You can actually buy the battery right here on iFixit, and in the process you'll be helping support their repair efforts.
iPhone X Battery: Replacement Part / Repair Kit
If you go that route, I'd suggest the Fix Kit, as it comes with all the tools and adhesives, both for the screen and the battery, needed to do the job right. Alternatively, you can save quite a bit by shopping around on places like Amazon, eBay and AliExpress.
I can't guarantee that'll fix the problem with your phone, but if it was mine, that's where I'd start.
Imagem de iPhone X Battery
Produto
iPhone X Battery
$34.99
Esta resposta foi útil?
Pontuação 1
3 comentários:
I will be replacing the battery!
Thank you Jerry for your time, I appreciate it very much!!
por
Update, it worked !! I appreciate it
por
@lizzzyaf Awesome! Glad to hear it and thanks for letting us know. :)
por
Adicionar a sua resposta
Liz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Duração total: 118
