Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
1608 Perguntas Visualizar todos
Why is my up key stuck even after I’ve removed the physical key?
My up ⬆️ key is stuck, I’ve removed it however it’s still continuously making my pages go up when I’m writing or using my laptop. I’ve attempted to add sticky keys but it still didn’t help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sounds like you had something sticky spill into the keyboard, which has effetely glued the key.
At this point I would just replace the keyboard unit as by the time you dig that deep to just fix the one key it’s just easier replacing the whole part so you also catch other keys which could fail soon. MacBook Pro Unibody (A1278) Keyboard and here’s the guide MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement or you can replace the full uppercase.
Imagem de MacBook Pro Unibody (A1278) Keyboard
Produto
$19.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Joe Bay será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 12
