Ir para o conteúdo principal
acer Aspire 3; how to make it faster
How to speed up the laptop
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Esta resposta foi dada inicialmente para uma outra pergunta.
To put it bluntly, no. To put it not as bluntly, the issue with upgrading most gaming laptops is that components like CPUs and GPUs are typically integrated directly into the motherboard. This makes upgrading these specific components difficult. Normally I would suggest using an eGPU, however, it does not seem that the Aspire 3 has Thunderbolt support.
I also saw some of your other questions. You can also speed up your machine by upgrading the RAM and an SSD.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
yeah, you can't unfortunately, it even says it on the acer website https://community.acer.com/en/discussion...
hope this helps!
Pontuação 1
Adicionar a sua resposta
Hello será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 16
Ao todo: 209
