Ir para o conteúdo principal
Released August 30, 2019 with a resolution of 240 × 320 pixels.
8 Perguntas Visualizar todos
Why is my keypad not working?
Keypad 789 is faulty
Esta é uma boa pergunta?
Pontuação 1
1 comentário
phone dead please my prv solution my mobile itel ace my mobile water damage
por
Adicionar um comentário
1 resposta
Solução escolhida
@ransonmugalla take a look at this guide Itel 2163 Disassembly - iFixit Repair Guide Step 4 (not the greatest images but it should work) shows the membrane and the contacts for your keypad. Clean the membrane and the contacts with an eraser. I like to use the erasers that are at the end of a pencil. If that does not work for you, check ideas like this one as well as on here for a deeper repair. Looks like this is a common issue with that model.
While you work on your phone and repair the keypad, take lots of good pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Ranson Mugalla será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 25
Duração total: 289
