Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Perguntas Visualizar todos
The headphone jack isn't working properly
The headphone jack only allows the right earphone to work. I can jiggle the connector and it breaks up. How do I fix it? It doesn't matter if I change to different headphones... it still does the same thing.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Check to see if you have broken a tip off any of your headsets. It may be in the iPod and preventing full contact.
Esta resposta foi útil?
Pontuação 2
This means that the headphone jack is becoming faulty and needs to be replaced. Simply locate the size of your iPod video and replace the headphone jack/hold switch. Very easy to do.
Pontuação 0
1 comentário:
What's the reason for the downvote? Sure, you should check the headphones out first. But this is a solid response.
por
Adicionar a sua resposta
SuzV será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 1,040
