Ir para o conteúdo principal
A gaming control system including a steering wheel and pedal assembly, compatible with PS2 and PC, released on November 4, 2005.
2 Perguntas Visualizar todos
Where to find a new potentiometer?
My wheel is an FGT Rumble 3-in1. The wheel will not center on calibration and driving is erratic. I believe the potentiometer is bad, but I am not sure. I would like to replace the whole board and potentiometer, but I cannot get through to Thrusmaster at all. Nor can i find the part. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If you remove the pot, you'll be able to measure its resistance OR its value will be written on it as it will be a 'standard' value.
Once you have that you then have to do a little more measuring. I suspect it will be a linear value (where at half a turn its value is half, at 3/4 turn its value is 3/4) but it may be a logarithmic (or audio) taper if the values you measures are not as I've said.
Once it's out, then simply google search on sites like Farnells or RS Components and it'll show up so you can order & replace. FWIW, I'd spend good money on one (def not the cheapest) as they take a lot of pounding.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
David Calhoun será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 93
