Ir para o conteúdo principal
Released September 20, Apple's largest and most expensive 2019 smartphone features a 6.5" OLED display, a triple-lens camera system, and greatly improved battery life. Successor to the iPhone XS Max.
Battery correction&programing iPhone 11/pro HOW TO?
so ive seen a lot of video on youtube and how one can switch the connector strips and program the battery and blah blah blah
I DONT want to do all that
my question is, if i had a orginal battery in the iphone at for example 99% health and i want it to read at 83% health instead, can i reprogram it to say 83% health without switch connectors and doing all that soldering?
what programmer would you suggest for 11 pro max updated latest ios, will i need a windows computer?
how do i do this, step by step if possible
please and thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
hello Nate,
The only way to do it the way you want is to use the RepairCall app, available only to authorized service technicians subject to additional restrictions. The mouse will not slip.
The answer is NO, there is no other way than the above (including the one you described in the question) to do it the way you want.
Esta resposta foi útil?
Pontuação 0
i'm not exactly sure why you'd want to downgrade the battery health capacity of the battery, but okay.
you can do it with the JC V1SE programmer. i can't speak for the 11, but i've changed the S/N for 7(+), 8(+) and SE2020 batteries so the factory ID and the read ID will be the same in 3uTools. i've changed the health reading in throwaway batteries just so i can know how to do it, but i would never do so to misrepresent the actual capacity of a battery that i was selling (kind of like rolling back the odometer of a car)..
Pontuação 0
Adicionar a sua resposta
Nate dog será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 223
