Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
612 Perguntas Visualizar todos
Did my MacBook fry 2 chargers?
Hey,
I have a macbook air early 2015 and having some problems with the charger. About 4 months ago the charger stopped working, so i went ahead and got a new one since it was a pretty old charger anyways.
The new one worked fine, but after about 2/3 months that one stopped charging as well. Well it didn’t exactly stop charging, the light sometimes lights up on the cable and it does say its connected sometimes (although battery % does go down). This wasnt an original charger, and after asking around on here (different account forgot which one lol) it was advised to try an original apple charger.
I did, and that one did charge it. But guess what, today that original charger decided it was time for retirement and stopped charging as well. First couple of times it just randomly stopped charging and worked again if i unplug and plugged the wall mount back in, but now its officially dead.
Have done SMC, PRAM reset, charging port is clean.
Any ideas?
Edit: added coconutbattery pic. This was made when it was on the (fake) charger.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Where did you buy the charger?
There are quite a few knockoffs which are sold as OEM which will not hold up and can in fact damage your system. Make sure you are using a properly wired outlet. I have seen outlets which have the common wire swapped with the hot wire kill the charger.
If you can still get it running let’s get a view on things using this gem of an App! CoconutBattery post a snapshot of the apps main window here for us to see.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Added! I bought the fake charger off amazon and later also the original charger. Right now it sometimes does charge when completely turned off, with the fake charger.
Original chargers seems dead to me.
por
@diamondgamer - At this point I would open the system looking for liquid damage and/or corrosion on the logic board, I would also take the logic board out as often the back side gets the damage first.
Post a few pics of anything that looks off when you compare with this guide MacBook Air 13" Early 2015 Logic Board Replacement
por
Adicionar a sua resposta
DIAMOND-_-GAMER será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 44
