"NEW" Battery won't retain charge
I replaced the battery, then completed the process of "conditioning" the battery by charging, then letting it drain completely. I did that 2X. At first, the battery had amazing run time-- more than 1 day. Now, one week later, it drains in less than 2 hours sitting idle.
Update (02/22/2023)
Here is the snapshot. I wonder, since this battery was manufactured in 2014, if the battery is worthless anyway? Perhaps I need a refund from Ifixit?
Update (02/24/2023)
OK, Here is the new snapshot.
Thanks for your help!
Update (02/24/2023)
Update (02/24/2023)
Here is the correct screenshot
Update (03/03/2023)
Sorry for the delay- I was on the west coast visiting my first grandchild.
You: "Now if you had the system shutdown during charge and you gave your system at least 10 hours of charge the battery heat lever should be lower than this. So did you not wait? Is the charger warm?"
Should I charge the battery for 10 hours and then check battery temp? Ans what would I expect a normal charging temp to be?
I will add that I returned home with the machine plugged in and fully charged. I used it for 2 hours with gargeband to drain the battery. When it has about 20% left I put the iMac to sleep and closed the lid. When I returned this morning the battery was completely drained. I am charging now- the battery is at 13% and the temp is 29C.
Here is screenshot of my system and current battery info:
Esta é uma boa pergunta?
3 comentários
Where did you get this battery?
por Duck
The battery came from i Fixit.
I have a reasonable amount of experience repairing my personal computers and phones since the 1980s. I’m good with a torx. Etc. I think the previous answer would give me insight, but anyone know why it would work fine for 1 or 2 days and then completely fail? Also, if I could determine the hotspots and thus see where the power drain might be, it would be a guess. Perhaps it’s time for a new laptop?
por chris036
@chris036 - It looks like the one you posted here is the same as well.
por Dan
