Ir para o conteúdo principal
Repair guides and support for your Philips TV.
238 Perguntas Visualizar todos
Some straight lines are apearing and darken image
i've got this problem that when i turn on the tv it have those straight lines apearing like the screen is brocken and its darken in some places but after a while, like if it was after warming up, the tv is fully normal, i dont realy know what can be happening, i have some images that can show what's happening, any ideas?
Update (02/23/2023)
hello friend, i posted the images as you asked, i believe the model of my tv is the 42PFL5603D/12
Esta é uma boa pergunta?
Pontuação 1
1 comentário
@linkoutsider post those pictures with your QUESTION. Edit the question and insert the images. Adicionar imagens a uma pergunta já existente
What is the exact model number for your TV?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@linkoutsider under any other circumstance I would have said this is a backlight issue. Until I've seen the lack of signal on the right side of the screen. This looks like a bad (failed signal) of the panel. You can try and check the LVDS cables and make sure they are not torn, corroded or otherwise damaged. Ultimately, it does look like a bad panel.
Esta resposta foi útil?
Pontuação 1
2 comentários:
ooh, i understand, the thing is that after some time it goes full normal you see? but i will check on that and give you some news.
i apreciate your help a lot, thank you.
por
@linkoutsider could be a failed capacitor or similar component. Get a can of freeze spray and spray it on the components, one ar at a time. If the picture returns to normal, you at least have the general area where and what to check.
por
Adicionar a sua resposta
Sh0uz3r será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 67
