Ir para o conteúdo principal
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
39 Perguntas Visualizar todos
Suddenly no sound, everything else looks normal
This morning I went to use my Wave as usual. After about 5 seconds the sound cut and I can’t get it to come back. Everything else looks and functions as normal. Any ideas what component suddenly died and how to fix it? Bose are no help … thanks!
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
@bmort time to take it apart and see what may have failed. Look for components that may have overheated, corroded or otherwise look damaged. Of course, make sure that all your "external stuff" like volume, connections etc is all still properly connected and set Bose Wave Radio AWR1-1W
por
Yes I'll take a look inside to see if anything is visually damaged. I've heard the battery can leak onto some important wires over time. If that's the cause of the failure I wish they'd not bothered to put a battery in the first place...
por
Adicionar um comentário
1 resposta
I think it's problem of thermal shut down by amplifiers chip
Keep in air circulated space amd try
Esta resposta foi útil?
Pontuação 0
1 comentário:
It's currently about 12 degrees celsius in the room where we use this and nothing over the vents so think that temperature shouldn't be an issue :)
por
Adicionar a sua resposta
Ben será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 31
Duração total: 362
