I restored my phone but it doesn't work or charge
i restored my iphone and now it doesn't charge or itunes doesn't recognize it? what can i do?
Esta é uma boa pergunta?
Try holding power button for 10seconds or hold down the home button and then connect the USB cord to the phone, see if itunes recognises it then. Is or was the phone jailbroken?
Esta resposta foi útil?
thank you for the tip but it doesn't work, itunes doesn't recognize the iphone. i tried changing the data cable and it still won't work. it gets to the silver apple screen and then it fades back to the charge screen but it won't charge either. HELP!!!!
Iphone 3gs with 6.15.00 baseband requires a custom firmware to restore. If you restore it through apple original firmware 6.15.00 baseband gets broken. Itunes will not recognize and will not charge it thats normal.
What you can do. To make sure it has 6.15.00 baseband download redsnow.
Try to charge it through a strong wall charger (ipad charger is the best).
Do not connect to itunes. Connect to redsnow to see if 6.15.00 is the problem.
If not let me know.
It may be a different issue..
Good luck ...
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 790
