Ir para o conteúdo principal
The Lenovo Legion Y530-15ICH is a 15 Inch gaming laptop released in 2018. The Lenovo Legion Y530-15ICH has a full HD screen with a long 10-hour battery to support everyday gaming.
7 Perguntas Visualizar todos
Audio jack output not working but input works fine
For some reason i cannot recieve any sound from my headphones when plugged into jack.
My observations:
  • Headphones work fine on another device
  • Default laptop speakers are working
  • When plugged into jack microphone works fine (headphones have combined microphone and sound in 1 cable)
  • System detect headphones properly
  • Haven't changed anything in the system before it happened, just tried to play some music and realised i got no audio
What i've tried:
  • Restarting the device (duh)
  • Trying another headphones (still no audio)
  • Installing newest drivers
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @kajetov,
Have you checked the headphone settings in Control Panel > Sound > Playback?
por
Adicionar um comentário
1 resposta
@kajetov your jack may have failed (even so your mic is working). In rapid succession insert and remove the jack a few times. Let's see if the contact comes free. You can also use a few puffs of compressed air to clean out some possible debris. After that, you will have to partially disassemble your laptop and physically check out the audio jack.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kajetov será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 107
