Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2376 Perguntas Visualizar todos
iPhone 4 doesn't charge, but loud speaker works?
Hello, I helped my sister fix her iPhone 4, as it showed the "Not Optimized for this Device" even though nothing was plugged into the dock. It turned out there was corrosion, so I replaced the dock with a new one. Everything went well, everything worked until I tried to charge it and nothing happened! :o The loud speaker, however, still works, though! What could be the problem? Thanks :)
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
The iPhone 4 dock and speaker assembly are 2 completely different parts. Before the 4, it was one unit but they separated them starting with the 4's. It could be 1 of 3 things that I can think of.
1) The replacement dock is defective. It's happened to me a number of times where a new replacement part is defective which is frustrating as all heck.
2) The connector isn't connected to the board completely. The dock connector has always felt weird to me when plugging it into the board.
3) There is a short on the board somewhere. If this is the case, get a new phone. Buying a new logic board is ridiculously expensive.
Just go through everything that you did and recheck all the connectors. It might help to get a magnifying glass and really inspect the connectors and the inside of the dock to see if everything looks as it should.
Good luck!
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
You may have shorted the battery. Grab a multimeter and give it a check. Also, if the battery was shorted but has a "bit" of connection plug the device into an AC adapter and cable and wait about 10 minutes and give it a shot.
Pontuação 1
Adicionar a sua resposta
D D será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 593
