Ir para o conteúdo principal
Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
L2 doesn't work
When I press the L2 button it works but it glitches a little as if it was being pressed lightly, I tried new ribbon cables and a new spring, but still had the same issue.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Its the rubber that is the problem
Unfortunate enough it has not been explained in this repair guide.
If its L1 then you have to remove L1 adaptive trigger, open it up and replace the rubber
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Akaza será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 160
