Pular para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
3001 Perguntas Ver todas
Can an iPhone 4 back be combined with an iPhone 4s front?
I have an iPhone 4s that is only 1 month old, but has water damage and Apple won't replace under warranty. I have access to an iPhone 4 with broken screen. Can the back of the iPhone 4 be combined with the front of the iPhone 4s? Any thoughts on how to combine?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
4 Soluções
Solução escolhida
the 4 and 4S phones have different screens.
iPhone 4S
iPhone 4 GSM
iPhone 4 CDMA
iPhone 4S Screen Imagem
Produto
iPhone 4S Screen
$39,99
iPhone 4 (GSM/AT&T) Screen Imagem
Produto
$34,99
iPhone 4 (CDMA/Verizon) Screen Imagem
Produto
$34,99
Esta resposta foi útil?
Pontuação 1
The iPhone 4S screen will only fit onto a Verizon iPhone 4, and only after one of the tabs are modified. If you have an AT&T iPhone 4 then the 4S display assembly will never fit.
Pontuação 0
That's good idea combined with an iPhone 4s front. You can have try. If you not, still not worry anymore. This APPLE ACCESSORIES can help you. From it, I have bougt some accessories with cheapest price. They said it celebrate Christmas at wholesale price. No matter what, can saving more is really good.
Pontuação 0
Yes.
You see, the hooks on the screens are a separate piece. You see, the if you remove the frame and replace it with the frame that fits the 4S, then there shouldn't be a problem with replacing the screen.
It's held with a pretty strong adhesive, so I'd be careful with removing the frame.
Pontuação 0
Adicionar a sua resposta
David Fink será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 2,514
