Ir para o conteúdo principal
Glow is designed with sleep in mind. Its self-dimming, warm light lulls you into better, deeper sleep.
4 Perguntas Visualizar todos
But now one of the two pogpins is broken
I live in Switzerland and have always charged my glow with a US-EU adapter. But now one of the two pogpins is broken and i need an other way to charge it. At the Moment i use a Labor Power Supply and charge it directly.
Output: 9V / 2A
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@pogopooc, Is it not feasible for you to replace the broken pin? On the previous question on this glow light we talked about sourcing the pins and referred to a video showing the process of replacing them on a different device.
Wireless Charging base failures or options? - Casper Glow Light - iFixit
I'm not sure, but I believe Digi-Key ships internationally; otherwise I'm sure you can find it elsewhere on sites like AliExpress; here's just the first example that came up.
https://www.aliexpress.us/item/325680249...
Please post a picture of your broken pin and the charging base and we'll see what we can do to help you get it working again.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks @Jerry i ordered the pogopins at Aliexpress and i will try to replace them. But for now the Light is charged again and also there was a Firmwareupgrade. Looking forward for the Pins. Thanks
por
Adicionar a sua resposta
Pogopooc será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 608
