Timer won't run through the cycle automatically but will manually?
The timer won't run through the cycle automatically but will if you do it manually
Esta é uma boa pergunta?
Hi Melissa,
The timer itself incorporates a small electric motor that's responsible for rotating the dial at a very slow rate, something on the order of 1/60th RPM, meaning it takes an hour to make a single rotation.
My son's washer died in exactly the same way; everything worked but the timer wouldn't advance. Taking it apart and powering the motor separately, I found that it wasn't turning at all. Unfortunately, on his washer the motor wasn't available separately so I had to replace the entire timer assembly when the problem was only the motor; I have no idea whether yours will be the same situation or not.
If you'd like specific information about replacement parts and/or repair instructions, we'd need to know the model number of your washer.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 149
