Ir para o conteúdo principal
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Perguntas Visualizar todos
How big a drive can an 27” late 2012 handle?
Hey all
How big a drive can an 27” late 2012 handle? Can i go bigger than a 256GB?
If yes, any suggestions to what drive i should use? I’ve ordered this - https://beetstech.com/product/solid-stat... - but bigger would be great.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sorry to tell you this is not the largest drive for your system. This model supports ether the Apple custom Samsung AHCI drive like this one 768GB or the slightly larger OWC 1TB Aura 6G SSD.
So I would contact BeetTech to alter your order the drive you would likely want from them or go with OWC.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks. Ill do that!
por
@Tony - if your set don’t forget to accept the answer - Thanks!
por
Adicionar a sua resposta
Tony será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 24
