Ir para o conteúdo principal
Released in May of 2019, the Xbox One S All Digital Edition (model number 1681) is a revision to the Original Xbox One S (released in 2016). This model of Xbox One S ships with no Blu-Ray Disc Drive (thus there is no disc slit at the front), exclusively providing downloadable and streamable entertainment.
28 Perguntas Visualizar todos
Xbox One S switches on for a random amount of time then shuts down
My cousin spilt water on the side of their Xbox One S and it seemed to work fine for a month or so, but now when turned on it stays on for anywhere between 30 seconds and 10 minutes before suddenly shutting down. I thought it might be either a faulty PSU, or its just overheating. So I've tried replacing the PSU, fan and even cleaned and reapplied the thermal paste but nothing has changed. Is there anything else that could be the problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
I would suggest replacing the heatsink entirely.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks, after looking for a replacement I've seen that my heatsink is missing the copper tubes found on other One S models. Ill swap it out for one of those ones and see if it helps.
por
Adicionar a sua resposta
Dengy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 33
