S7 Edge Turned off and won't turn on
Hello, as I mentioned my device turned off suddenly with some kind parasites on, I was able to turn on several times more but then it turned off completely. When I connect it to power supply, nothing happens that can indicate device is working, like charging light or image on screen etc. So, I connected power meter and checked out that it is drawing power or not. When I press power button It draws around 0.02 amps, I assume that is boot current. Then I searched for this situation and find out that problem might be a failure of power ic. To be sure I started testing basic components in the image and found out one short circuit in red circle. I'm curious about this is normal or not? Anyone knows what cause this problem or what should I check? Thanks in advance.
Esta é uma boa pergunta?
