Ir para o conteúdo principal
O Lenovo ThinkPad X1 Yoga 2ª Geração é um notebook de 14” lançado na primavera de 2017 e pode ser identificado pelo número de modelo TP00076C.
Does the Yoga 3nd Gen Battery fit into a 2nd Gen Notebook?
Hello, i have a lenovo thinkpad x1 yoga 2nd gen (Model 20JD) and i want to replace the battery, because it is very old.
Sadly the iFixIt store does not provide a battery for this notebook, but for all other gens. Because the battery of the 3nd gen looks very similar to the one of the 2nd gen, i ask myself if i could just use this one?
Thanks in advance and best Regards,
Sandro
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @gafhdrz,
Unfortunately the batteries for the two model ranges are not interchangeable between the models.
Here are images showing the Lenovo part numbers (FRU number) for the 11 batteries that are compatible with the Yoga x1 2nd Gen Type 20JD laptop and the 3 batteries that are compatible with the Yoga x1 3rd Gen type 20LD laptop. (FRU = Field Replaceable Unit)
Type 20JD
Imagem
Type 20LD
Imagem
(click on images)
To find a replacement battery for the 20JD laptop, search online using the part number only (any one of the 11) to get results for suppliers that suit you best.
If you have the Lenovo Vantage program installed in the laptop it will tell you information regarding the battery in the laptop e.g. what your battery percentage is at alongside it's charge capacity, model number (part number aka FRU number) and manufacture date. You can compare the FRU number with the list in the image above.
Here's the hardware maintenance manual for the Lenovo Yoga x1 2nd Gen 20JD laptop. Go to p.73 to view the procedure to remove the battery.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Hi, thank you very much for the detailed answer, it helps alot!
por
Adicionar a sua resposta
Sandro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 609
