Ir para o conteúdo principal
Um Tablefone econômico de 6'' com resolução 1080p, disponível através da T-Mobile e fabricado pela Coolpad. Número do modelo C3701A. Foi lançado em agosto de 2017.
My phone keeps saying that it's charging when it's not
Sorry for incorrect phone model, but I couldn't find my phone model in the list of models, so I just went with the one that most closely resembles my phone. I have a T-mobile Revvl 4, and the phone says that it's charging when it's not and the screen just randomly turns black, and it's had issues like this for 9 months. I have to constantly turn it off and then back on again to get it to temporarily work again. However, then the screen just turns black again, and the issue continues. My phone briefly stopped having the issue for about 2.5 months. On December 14, it was raining and only a little bit of rain got on my phone, but not enough to cause any water damage. I'm not sure if it's because of the rain or not, but now it's going back to saying that it's charging even when it's not, and the screen is randomly going black again.
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
Problem Internet
por Compartilhar
@ricardyoctiard problem is that there are not enough words to help you. Are you asking a question or providing a solution?
por Compartilhar
Adicionar um comentário
2 respostas
so my only guess is that the fuses on the board that take in the charge and send it to the main chip are faulty and the screen randomly turning off I don't know much about that try updating the phone see what happens
Esta resposta foi útil?
Pontuação 0
@kaylani could be a battery issue. I would definitely start with that. Also, check the charging port. Make sure the are no bend pins, corrosion or debris that are creating any obstruction. Check your circuit boards for corrosion and other visual cues that something does not look right. You can always post images with your question. That way we can see what you see. Adicionar imagens a uma pergunta já existente
Pontuação 0
Adicionar a sua resposta
Kaylani Thomas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 33
Ao todo: 708
