Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
First generation of Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
93 Perguntas Visualizar todos
Pergunta Encerrada
New Front does not fit exactly
After i installed the new front, everything worked like expected, but when i push the display at the edges it moves a bit back.
Thats not as intended...
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
2 respostas
is there a chance that some of the little rubber spacers have gone missing from around the frame edges?
this is about all i can think of
Esta resposta foi útil?
Pontuação 0
Comentários:
I will check that. But thx for your help.
por
If yes? Where can i buy them? The new display i installed has none of them.
por
If your not familiar with the parts then you need to know that not all replacement parts come with the outer screen bezel. Look at your old part you will see a thin plastic edge that flipped over you see the the bezel frame attached with the two sided LSC-300 adhesive. Without the bezel the screen will seem to be slightly smaller than it should. Check to see if that could be the issue.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 530
