Why is my tower's power LED blinking amber and not displaying?
Why does my computer's power LED keep blinking amber but doesn't display anything?
Esta é uma boa pergunta?
Then you need to remove the faulty unit and replace it with a good one. Just follow the procedure described at p.19 on the user manual, the size of the PSU you need to buy varies depending on the specific model you have, a common PS2 unit should fit into the tower, but you'd need an SFF unit (like this one) if you happen to have the smaller model. Here's a list of the most common PSU form factors.
Let us know how the repair goes and don't hesitate to ask if you need more advice
Esta resposta foi útil?
Many reasons that will give you a yellow light. What has caused this issue, it was working fine and all of a sudden it stopped - was there a power glitch?, have you moved the computer as sometimes the memory and or other connections inside get loose. I would open the box if you are comfortable - ALWAYS UNPLUG THE POWER. clean the inside of the machine and check to see if nothing has been moved and the memory is installed properly. Hopefully that should resolve the problem else you may have a bad motherboard and or a power supply that needs replacement. Take it to a repair shop if you you are unable to work on it.
It is probably a diagnostic code or it is in a sleep state, search up your model's manual on Google. Mind if I ask by blinking does it blink than stop or just continues blinking
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 17
Ao todo: 1,146
6 comentários
Please check the user manual at this link https://dl.dell.com/topicspdf/optiplex-7..., p.45 (Power LED Diagnostics) and report back what's supposedly preventing the system from booting so that we can try to sort it out
por Simone
It's the power supply unit failer
por Ntuthuko Mbhele
Hi @Ntuthuko Mbhele You don't mention if the amber light is steady or blinking.
por mike
The light is blinking
por Ntuthuko Mbhele
Hi @Ntuthuko Mbhele certainly looks like power supply as Simone says but would do as branda suggests reseating RAM, etc. and cleanibng dust out.
por mike
Exibir mais 1 comentário
