entire pre-lit Christmas tree won't light
entire pre-lit Christmas tree turned off and won't turn back on”
Esta é uma boa pergunta?
Hi Donna,
Just because it's a pre-lit tree doesn't mean the lights are any different than any other Christmas light string, so check out the guide to fixing broken Christmas lights.
Esta resposta foi útil?
This is a 5 year old pre-lit tree, and I did replace all the bad bulbs,, which took 2 hours last weekend. It was lit, and then (like a switch was flipped), the entire tree turned off. I checked the outlet, and it is good. Its something with the tree, which is completely decorated :(
Same here. Lights started flickering and wouldn’t turn off with foot controller. Had to unplug then lights wouldn’t work.. one of them!
Nancy
meant to say none of the lights work
Nancy
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 591
3 comentários
What model/brand Christmas tree?
por Ben Capehart
It is a 9 foot Frontgate tree, its 5 years old, I don't know the model.
por Donna Dubbs
I changed the fuse it the tree plug ( took 225 5A fuse). it worked!! However, the tree still blows a Fues after a day or two. I just can't figure out why it started doing this, after 5 years. Help!
por Donna Dubbs
