Ir para o conteúdo principal
Repair guides and support for top and front loading Whirlpool brand washers.
400 Perguntas Visualizar todos
Why does my washer drum keep rising as it takes forever to drain?
I noticed this lately. It seems to drain forever, and the drum keeps rising. Is there a clog or something somewhere?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @wonderingwoman
Here's the tech sheet for your washer model (if it is the WTW4816FW2 that you asked about before).
Run the diagnostics as described in the guide and check what error code, if any, show up.
On p.11 it shows the possible causes for a "won't drain" problem that may also help.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
WonderingWoman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 23
