Ir para o conteúdo principal
Repair guides and support for top and front loading Whirlpool brand washers.
404 Perguntas Visualizar todos
Washer tries to spin three times then quits and drains
My whirlpool attempts to start spin cycle several times then gives up and drains. Clicking sound when spins are attempted. Video attached. Drive hub? Belt? Thanks all!
https://drive.google.com/file/d/1tc0a7_h...
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi,
Sounds like a clutch problem.
What is the model number of the washer?
por
WTW5000DW1 is the model
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
Here's a link to a parts supplier that may help.
It has a video that shows how to replace the clutch assembly (aka drive pulley). If this is the problem search online for W10721967 to find suppliers that suit you best.
it could also be a worn drive hub connection. (search online using the manufacturer's part number to find suppliers of the kit that suit you).
Either way you'll have to access it to find out.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks I’ll give it a shot!
por
Adicionar a sua resposta
K F será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 34
