The process com.android.phone has stopped
This error keeps coming up when I press OK it comes back constantly even after clearing data for the phone app how do I fix this without reseting it?
Esta é uma boa pergunta?
If you see the error message “Unfortunately, it has stopped
process.com.android.phone
or unfortunately stop
com.android.phone
Process after installing ROM
If you are new or update your firmware, there are actually several ways to fix it
The error message is triggered by phone or SIM toolkit app
So, if you are constantly getting the “Unfortunately, the process com.android.phone has stopped” error.
Esta resposta foi útil?
Solution #1: Disable automatic date and time
This simple setting change can help you remove the error message for good. To change this, go to Settings from the Home screen, then tap
Second solution: Clear data and cache
Third solution: Clear data and cache
Boot the device in Safe Mode
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 121
