MBP can't turn on, dim Magsafe charger
Hi all, I can't seem to turn on my MBP and the Magsafe charger shows a very dim yellow light when plugged for charging. It has never happen before. The laptop has been well taken care of, smoke-free environment, zero drops or any liquid damage.
After reading on here and taking it apart. I've tried PRAM, SMC, unplugging the battery, swapping the DC-In circuit from another working MBP. I've also tried swapping Magsafe chargers but no luck.
All I did before was turn it off, plugged in the charger, Magsafe lights up as per usual and a minute later, it dimmed and I can't turn on the laptop.
Help please! Thank you in advance.
EDIT: Should I apply thermal paste to the GPU/CPU? Would that work? Also, I'm considering dropping in the logic board from a late 2011 13" model. Would it fit?
Esta é uma boa pergunta?
