Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Perguntas Visualizar todos
Replacement battery not being recognized
Hello! I recently replaced the battery on my Early 2015 Macbook air 13" and I'm not able to get the laptop to recognize the battery. It won't stay on without the power cord, and the battery status won't show up on the menu bar. I tried resetting the SMC - holding shift, control, alt and power button for 10sec - and that has not seemed to resolve the issue. Any help would be greatly appreciated!
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
What is the color of the MagSafe charger LED? Amber or Green or not lit
por
It starts as green and then goes to amber
por
Adicionar um comentário
2 respostas
@johnvinson91 - Good! Now let it sit for at least eight hours ten would be even better the LED should be Green.
Then give it a fresh try.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I've let it continue to charge for 12+ hours a couple times already. It continues to stay amber colored and will turn off without the charging cord. Thank you for your help trying to figure this out!
por
@johnvinson91 - OK, let’s install this gem of an App! CoconutBattery take a snapshot of the app main window with the battery info tab opened up. Post it here so we can see it to.
por
I have the same problem. I replaced the battery with an iFixit battery about a year ago. It has been running fine until today when the battery is no longer being recognized. I don't know if it is a software problem (Latest Mac OS refuses to recognize aftermarket batteries) or if the battery is now defective, of if there is a hardware problem with the power circuitry. When I boot the Mac (Air 13" early 2015) the battery symbol has an X in it. When I look at the System Report, it shows that the Full charge capacity is 0 and that the cycle count of the battery is 0. When I run Coconut Battery app, the app dies.
Pontuação 0
Adicionar a sua resposta
johnvinson91 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 34
