Ir para o conteúdo principal
Sony Cyber-shot DSC-W5 5.1 Megapixel
10 Perguntas Visualizar todos
The lense doesn't open when I turn the power on
i don't think it was dropped but the lense doesnt open when i power up
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It is possible that your lens is simply stuck. This can happen due to grit and grim on the lens body, or it may have been turned on with a blocked lens and jumped the mechanism. Check this site for some decent tips in how to free the lens. It is generic, but still may work for your camera. If you need to get deeper into the lens, use one of the guides from here. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
suzanne será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 820
