lid lock engages and disengages constant
Whirlpool wtw4855hw2 lid lock engages and disengages constant no other feature works.
Esta é uma boa pergunta?
Hi,
Here's the tech sheet for the washer.
Run the diagnostics as described in the tech sheet, to find out whether the problem is a lid switch fault (F5 E1) or a lid lock fault (F5 E2).
There's a code chart in the tech sheet that shows how to decode the lights to know what the error code is:
Fill/Sensing + Rinse + Done = F5,
Done = E1.
Spin = E2
In any event unless it is a wiring problem between the control board and the lid lock assembly (see wiring diagram in tech sheet) or a fault in the control board, most probably the lid lock assembly will need to be replaced. The lid switch is also in the lid lock assembly
Here's a link to a supplier that may help, as there's a video in the page that shows how to replace it.
If you determine that the problem is in the lid lock assembly, search online for W11307244 to find suppliers that suit you best.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 49
