Ir para o conteúdo principal
The OnePlus 8 Pro is an Android smartphone from OnePlus. It was Released in May of 2020.
9 Perguntas Visualizar todos
Why is my new battery going dead in minutes?
I purchased a battery from ifix it because I thought it would be better than saving money and buying from Amazon. Ever since I installed it my battery life has been FAR worse than before I replaced it. The phone will charge to 100% only to fall to 20% I'm under 5mins and then from 20% to 0% it will go down slower but not as slow as I would expect. I think that the phone is misreading or something and thinking the battery is full and not charging all of the way because it says 100%. Any help is appreciated 👍.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Hi
It could be a faulty battery
However
It could be that the battery needs recalibrated as new battery’s need to “learn” how to read their percentage properly
I have had loads of them that act like this and it’s usually that or the battery connector just needs reseated
I would try charging it up fully then draining it till flat a couple times to help recalibrate it and if the issue persists contact iFixit to see about getting a replacement or a refund
iFixit support is great so they will make it right:-)
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 2
2 comentários:
Ok cool thanks for the help, since I already tried doing this calibration process I'll go ahead and contact ifixit.
por
@sauce_boss
That’s the best thing to do
Iv contacted them before
They are amazing and they will make it right:-)
por
Adicionar a sua resposta
John será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 29
Últimos 30 dias: 53
Duração total: 647
