Ir para o conteúdo principal
The Dyson Ball Multi Floor Upright Vacuum was released in 2012 and can be identified by the Dyson tag DC40. It is very similar in design and mechanical operation to its earlier counterpart, the DC41 Animal.
19 Perguntas Visualizar todos
My Dyson works great when upright but doesn't suck well on the floor.
WHen It's upright the hose works fine, but when running (normal use) it seems to not have good vacuum. Is there a seal that's possibly broken? Where are the most common failures?
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
Hi @nixtechguy
Most of the time the bottom hose will have a issue if it’s not got suction when coming out of the upright position
Check the hose in the picture below
Check that it’s seated correctly and that there aren’t any cracks in
Also try not to let it go once it was been pulled out(pulls towards you to unlatch)as they can hide away if your not careful
It you cans see any let me know by commenting on my answer and we can further look into things
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
davew será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 39
