4 Red Blinking Lights on the SONY OLED tv
Turn on the tv, runs for about 5 minutes, then shuts off with 4 red blinking lights. Tried hard reset/factory reset and the tv goes into reset mode, shows the Android logo, gets through setup, then shuts off. Tried to connect the BL_ERR to ground, but did not fix. Then replaced the power board with new board, still no fix. What next?
Esta é uma boa pergunta?
18 comentários
Hi @dave2849,
On a Sony, the 4 blinking red lights indicate an error with the backlight inverter or power board. Have you taken the back off the TV yet? If not, could you do so, and remove the power board (be careful as there are capacitors there that store High Voltage!) and take high resolution pictures of both sides? Make sure it's as nice and in focus as you can get it.
Then, update your original question with those pictures, following this guide.
por Geir Ove Andersen
/Users/Dave/Desktop/IMG_2473.jpeg
/Users/Dave/Desktop/IMG_2472.jpeg
por DaveC
@dave2849 See the answer from @jayeff below; There is conflicting information online about the blink and what they signify, but the manual is from Sony, so I'd trust that more so.
@dave2849 this T-con board has at least 1 test point. Post an image of it with your QUESTION.
por oldturkey03
Just posted the front/back images.
por DaveC
Exibir mais 13 comentários
