battery and the touchpad connection melted
Hi, i tried to remove the joystick by using the heat gun but the problem is that the battery connection and the touchpad connection melted even with aluminum on it. Is it still possible to fix it?
Edit: the plastic also melted in the middle of the motherboard where the headphone jack is, is that a issue or not?
I would appreciate any answers! :)
Esta pergunta é pertinente?
10 comentários
@redmoka depends how bad it looks. Post some pictures with your QUESTION so we can see the damage. Adding images to an existing question
por oldturkey03
Just added pictures on my question.
por streamer993@gmail.com
@redmoka
Hi
From the photos that are you posted the connectors aren’t on the board
If you can post a close-up of the pads (where the connectors once were)we can see if it’s all good to go(ready to resolver some new ones)
Also as for the plastic on the other side of the board : try and heat it up a little (really not a lot) just enough to help it separate from the board and carefully try and peel it off of the board:-)
por HelloMacOS
@hellomacos i just posted the better zoomed picture for the connectors.
@redmoka
All but one of the pads look ok(in the new photos)but if you can clean the burn marks off with some isopropyl alcohol and repost the pictures that would give us a better indication of what’s going on so that we can be certain:-)
por HelloMacOS
Mostrar mais 5 comentários
