Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Intermittent hingle cable; replacement?
Was given a MacBook Air (13-inch, Early 2015) 7,2
The screen will go blank, the keyboard backlighting stops. and the keyboard goes dead. If I delicately wiggle/flex the screen vs. the body, it will come back to life again.
This sounds like the cable through the hinge is at fault.
Is it replaceable? What part#, etc?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I bet you the issue is at the logic board displace connector. Corrosion on the solder joints is likely. I would inspect the area, post a pic so we can see things.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
fat_fingered será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 59
