Ir para o conteúdo principal
2.3L 4cyl or 3.0L V6, 6th Generation
Window won't go up
My back driver side window won't go up.
It will go down using the driver and back switches but when putting it up, it will jolt/move slightly and then will make a slight sound and then nothing. It did go up once by pushing it up with my hands on the window but now it won't move past a certain point at all. When it was 'up/closed' before this, it never completely closed and would fall down slightly itself and I had to push it close with my hands on the glass.
Any suggestions? Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @beccax,
Have you done diagnostics on this yet?
By the sound of it, the window mechanism sounds like it's either gummed up and needs a cleaning, or at worst in need of replacement.
You'd need to take off the door card (panel) and inspect what happens when you press the switch.
Esta resposta foi útil?
Pontuação 1
1 comentário:
@beccax besides the excellent answer by @geirandersen here are the parts of the SM that are showing you how to check the electrical parts 1998 2002 Honda Accord Power Windows of your power windows and how to get to the mechanical parts 1998 2002 Honda Accord Doors and work on them . I do agree this sounds like either a bad motor or a misaligned regulator.
por
Adicionar a sua resposta
Becca será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 119
